I have been experimenting with ReJig's ability to author simple DVDs, which is exactly what I want. It suggests that you can create chapter points by specifying a txt file. However, I do not know how to create this file or what format the file should have. Does anyone have an example of such a file?
AFAIRC it is the same format as in ifoedit. So it is just a plain text file with frame numbers (one framenumber per line).
Mpeg2Schnitt is able to save a chapter list in this format and can be used as 'visual chapter editor'.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Thanks, that worked exactly as you described. This type of response is exactly why these sites exist and why they are so valuable. Thanks again.
Authoring Blu-ray with chapter points
By ikarishinji41 in forum Authoring (Blu-ray)Replies: 2Last Post: 28th Jan 2012, 05:44 -
How to convert multiple avi's to DVD with chapter points between each?
By Pierre1 in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2009, 07:38 -
How do I set chapter points in an already authored DVD?
By midders in forum Authoring (DVD)Replies: 6Last Post: 25th Sep 2008, 17:57 -
question about how to add chapter points to already made DVD
By jimdagys in forum Authoring (DVD)Replies: 15Last Post: 24th Apr 2008, 14:44 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39
