I'd like to know how to insert a black strip on the video so i can put a new subtitle over a previous existent (permanent) subtitle.
The video im going to encode has already 2!! permanent subtitles...so i need to give a cleaned to burn a new subtitle...My only idea was to put the traditional black strip under the new subtitle and over the old ones...but i don't know how... I tried the medusa but it was kind of amateur. Can anyone help me? THANKS!! :)
I would artificially "widescreen" the video with a matte. Adobe Premiere, Vegas, TMPGENC, any number of programs can do it. Do the new subs as DVD subs.
So...If i "widescreem" the video (it is on the process of encode? I use TMPGEnc...it is easy isn't it?) the old legends will be under the black part of the widescreen? But won't i lose to much image ?
And how can i do the sub as a DVD sub? Becouse the last time i tried to do that with ifoedit i burned a DVD without any subtitle.... after that i never tried again, but im realy interested in doing that -
Hi, just an idea.(dont know if it will work)
cant you use the logo filter in virtualdub/mod to put a black strip over the 2 subs, and the subtitle filter to put the new sub on top of it?I love it when a plan comes together! -
You won't lose too much image.
TMPG is simple, use the CROP filter, and then select MASK on the bottom and add pixels as needed. There is a preview. Dummy proof.
Use authoring software that supports subs. I would use Subtitle Workshop in combination with DVDWS2. And then I'm done. Easy there too.Want my help? Ask here! (not via PM!)
A way to insert black in frames' center and vertically push apart video?
By sincostan45 in forum EditingReplies: 5Last Post: 10th Jun 2011, 18:40 -
How to strip audio or subtitle tracks off a Blu-Ray Disc
By ppeterr in forum Authoring (Blu-ray)Replies: 6Last Post: 2nd Jul 2010, 14:45 -
How to insert one or more subpictures in .SUP subtitle
By Shone in forum SubtitleReplies: 12Last Post: 21st May 2009, 10:45 -
Insert Vietnamese Subtitle
By balonglong78 in forum SubtitleReplies: 19Last Post: 18th Jan 2008, 13:28 -
how to insert subtitle in Final cut pro 4??
By yunakokimama in forum SubtitleReplies: 0Last Post: 12th Dec 2007, 18:16
