how can i keep the same quality of the movie but alos have the .srt file in the .avi file? thnx
Hi-
If you keep the subtitles external, then there's no effect on the video. I assume you want to "burn" the subs into the video, in which case you'll definitely have lowered quality. You'll have to reencode the AVI to get the subs into the video, and the quality degradation may or may not be noticeable just from the reencoding. Burning subs into the video while reencoding will make the degradation obvious, as you'll get all this noise around the subs. The results may still be acceptable to you
How can you do it? It could be as simple as just opening the AVI in VDubMod, adding the SRT subs via VDub's TextSub Filter, choosing a codec and a bitrate and running a couple of passes. Of course, if you've never done it before, it may not seem all that simple. I might suggest AutoGK for the job, or one of the guides on this site to show you other ways to do it.
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 07:35 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
What am I doing wrong? AVI to DVD with srt subtitles.
By du2vye in forum ffmpegX general discussionReplies: 8Last Post: 21st Oct 2009, 13:54 -
DVD to *.avi rips with *.srt subtitles
By WhiteFox in forum Video ConversionReplies: 0Last Post: 3rd Sep 2008, 11:51 -
Converted .avi only plays subtitles
By Kagredon in forum ffmpegX general discussionReplies: 3Last Post: 28th Aug 2007, 09:54
