Results 1 to 25 of 25
    Jun 2005
    Orlando, FL
    Can SVCD2DVD handle multiple .ts files and join them into one DVD?
    A64 X2 3800+ | Chaintech VNF4 Ultra | EVGA 6800GS | 1GB Corsair PC3200 | Maxtor DM9 120GB SATA | Antec Sonata II | Dell 1905FP UltraSharp
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Wow. "Great minds think alike".
    I had a domestic situation yesterday, whereby my wife deleted a CSI Miami episode from the Sky+ Planner... Anyway a US collegue sent me a HDTV version of said episode.... but here in the uk that doesn't get you very far. Thus i had to make SVCD2DVD do HDTV2DVD....
    So in your own case you need to join the ts parts:
    copy /b "nameofthing*.ts" "joinednameofthing.ts"
    at your command prompt. (assuming you have a common name like xxxxxx.part00xxx.ts)
    Then load the ts file into SVCD2DVD as normal.
    Currently it is a personal build but if you want to test let me know.
    FYI: the result is phenomenal with HDTV material..... on my setup it is better than Sky and at least equal to a retail DVD....
    Jun 2005
    Orlando, FL
    Sorry I don't follow you totally. I have a .ts file with 3 parts. I tried to drag the 3 into SVCD2DVD v2. That didn't work. Are you saying one BIG .ts file would work, while 3 small ones don't?
    If I use the /b command, do I first enter all three parts names then list the name of the output file I want? Sorry, never done this before so I am a noob at command prompt stuff
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    if you have:
    mymovie.part001.ts
    mymovie.part002.ts
    mymovie.part003.ts
    mymovie.part150.ts
    for example
    then bring up a command prompt. change directory to the folder where these files are (cd \blah\blah\blah)
    then do
    copy /b mymovie*.ts mymovie.ts
    This will concatenate the parts into one big file....
    This is mandatory if you have a Transport Stream (HDTV or otherwise) which is split up.
    Then you would add the mymovie.ts (i.e the big one!) to SVCD2DVD and process as normal... in the build which i have, which you are welcome to test.
    Things which are different as far as S2D is concerned is that:
    - .ts files are assumed to be HDTV material and so need reencoding.....
    - Typically HDTV stuff is 1920x1080i or 1280x720p and so a 16:9 AR is assumed.
    - NTSC is assumed too for the resultant DVD.
    - Autofit is enable for such assets
    CB
    Jun 2005
    Orlando, FL
    That sounds good to me. I would definitely need the new build that works with .ts files then correct? Yes, please send!
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Is it HDTV material?
    Jun 2005
    Orlando, FL
    Yes. I have 3 .ts files (3 disks) that comprise the HDTV content. I am joining them into one file now per your instructions. Seems to be going good.
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    ok. I will send you a build to test.
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    You will need to remind me of your email address. PM?
  10. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Email sent. I'm off to bed. Let us know your test results in the morning!
    Jun 2005
    Orlando, FL
    I am going to let it run overnight for me, I will report back!
    Jun 2005
    Orlando, FL
    Any news on getting the updated build to test?
  13. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I have sent it to you twice!
    Check your PM
    Jun 2005
    Orlando, FL
    Check your PM
    Ok got it now!
  15. any chance of getin hold of that copy chris love to test it
    thanks brit
  16. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Sure. Drop me an email.
    Jun 2005
    Orlando, FL
    Well my first project went GREAT, but I tried another HDTV project and it went horrible. No application errors, Nero burned fine, BUT, the movie was overly compress and only took up 1/3 of the entire disk. I used autofit, I don't know what happened
  18. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you email me the log please?
    Jun 2005
    Orlando, FL
    Email sent!
  20. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I have resolved the issue (S2D thought your file was over 6 hours long!!!) and have sent you a new build to test.
    Jun 2005
    Orlando, FL
    Gracias! I will test tonight!
  22. Member
    Jun 2005
    Orlando, FL
    Got newest build, and it worked like a charm! Used the DVD Shrink option and Nero worked flawlessly, as well as auto shutdown! Thanks! I can't wait for the HDTV2MPG to get into a final release!
  23. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Excellent news!! Thanks for the testing.
    SVCD2DVD with HDTV support will be posted ASAP (as soon as i resolve a menu issue)... However, FYI, I have written a new app which is has just the HDTV to DVD functionallity called..... wait for it: HDTV2DVD!
    It will be availiable soon as freeware as soon as more testing has been done.
  24. Member Soopafresh's Avatar
    Jan 2004
    ChrissyBoy - What a kind soul you are Looking forward to trying it out. Just as a reminder, 720p runs at 59.94fps and at least half of the HDTV stuff being broadcast here in the States is 720p.
  25. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Soopafresh:
    Good point. I have tested a couple of such sources with positive results... just waiting for some feedback from some testers before i release. If you want to test too drop me an email.
