I am unsure where this should go so sorry if it's in the wrong forum.
I have tried to download home movies from my digital video camera but the results are rubbish. I have a couple of programes I've tried such as Win dvd. Cucusoft and Dvd santa, but each time the result is pixalation to the extent of unwatchable and sound problems. When I plug directly into the tv or my pc the picture is perfect but when trying to burn to disk the problems are there.
Can anyone advise me on software for this.
Many thanks.![]()
I don't own a digital camcorder but maybe I can help a little.
How do you transfer the video to your computer? Do you use firewire/usb? Or do you capture it through a capture card? Either way should produce good results. Or does your video camera record to a minidvd?
A few more details on your camera model and methods used will help us help you.
Assuming your converting to dvd make sure your converting to mpeg2 at one of the acceptable dvd resolutions (352x480, 704x480, 720x480 for ntsc).
After you give us a little more detail I'm sure others will be able to offer some more advice.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
when it comes to downloading movies from mini DV cam.stand alone DVD Recorders are the best
My cam is a JVC Mini DV AND I use a USB cable. It actually goes onto a cassette.
You do not want to use USB cable for that.
Buy firewire card with firewire cable (costs few bucks) and install it in your PC.
See in your camera user manual, how to connect your camera to PC, using the firewire cable.
After that you will be able to transfer video from your camera to PC without any troubles and any loss in quality.
Other option is, as MJA said, to use a standalone DVD recorder which is the simplest and the best.
Read similar topics in DV section on this forum - there are many topics about this.
HD video camera hookup to digital projector
By MTguy in forum Newbie / General discussionsReplies: 4Last Post: 1st Feb 2011, 20:08 -
SD Video Camera Vs. HD Movie Mode on Digital Still Camera.
By CP/M User in forum Newbie / General discussionsReplies: 20Last Post: 20th Nov 2009, 15:57 -
Need advice on compressing video from digital camera
By lopardo in forum Video ConversionReplies: 3Last Post: 17th Jul 2008, 21:43 -
Using my digital camera as a video player...
By meatloaf in forum Video ConversionReplies: 8Last Post: 30th Dec 2007, 21:55 -
Compressing digital camera video
By kaz219 in forum ffmpegX general discussionReplies: 4Last Post: 25th Jun 2007, 12:12
