Hello everyone, I'm trying to use DVD Shrink to make these VOB files smaller. I already Split this .avi into 2 seperate files, then converted each .avi file to VOB files with DivxtoDVD. I can burn the first part of the .avi file onto 1 dvd, with good quality but when I try to burn the 2nd part, it won't even fit on the DVD!! So I'm trying to use DVD shrink to make the VOB files smaller so they can fit onto a DVD so i can watch it on a stand alone dvd player. I loaded the .VOB files, and i clcked back up, it burnt the dvd super fast and i knew it was too good to be true, when i tried to play it in the dvd player it was black and white and the screen was going crazy. Reminded me of the time i tried to play a VCD in my dvd player. Any ideas on how i can minizie these .vob files so i can burn onto a dvd? Thanks.
Sounds like you are playing a PAL video on your NTSC TV, although since you split a single avi into 2 parts, I don't know why one would work and the other doesn't.
Try using DivxtoDVD on the original file. Then using DVD Shrink.Google is your Friend -
I don't understand why you would want to have a film split over 2 discs, especially as a dvd!! Stick to vcd/svcd then. Encode each part to mpeg2 (alter bitrate if need be for file size) and join with dvd authoring program. Use shrink after to reduce file size if need be. DVD Shrink will do it. You have to be close to 8.5gb upwards for it not to be able to do it. In which case, just run it through shrink again.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
Problems backing up DL dvds using DVD Shrink and ImgBurn
By ManuBumb in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2009, 22:35 -
Will using the pc while using DVD shrink cause problems to editing????
By jones24 in forum DVD RippingReplies: 8Last Post: 7th Oct 2008, 11:39 -
problems with DVD Shrink 3.2.0.15
By janefield in forum Newbie / General discussionsReplies: 6Last Post: 25th Aug 2008, 08:20 -
dvd shrink problems
By anahata3 in forum DVD & Blu-ray WritersReplies: 9Last Post: 9th Jul 2007, 12:07
