For those who were early adopters
http://www.macupdate.com/info.php/id/6351
The software has an auto notify feature if you need this update... when you launch you will be told, or you can do "Help > Check For Updates" and it will tell you then.
Make sure you need it, before taking the time to download it.
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 12:02 -
Toast 7
By JordanBlake in forum Newbie / General discussionsReplies: 0Last Post: 7th Jun 2010, 15:07 -
Toast 9
By lawnman in forum MacReplies: 1Last Post: 11th Mar 2008, 22:45 -
Toast 8.0.3
By lawnman in forum MacReplies: 1Last Post: 17th Nov 2007, 06:00
