TV tuner/capture card: AverTV USB 2.0
when i capture a VHS tape to my second HD (60 GB/7200rpm) using vdub 1.6.10 with HUFFYUV 2.1.1 using the WDM option in device menu i have a lot dropped frames (about 25-30%). after this i tried the option 1 in the device menu of virtualdub which is the name of my card (=AverTV usb 2.0) and i found that it drops 17 frames in the beginning and then 4-5 frames per 1000 captured frames. the strange for me is the big file size in this case. For an hour it seem to be about 50+ GB. Are all these normal?Can i do something to reduse the file size?
And something else...using a usb 2.0 external HD for capture will have problem such as dropped frames?
Filesize seems normal for me....
In case you want less filesize for your captures, use an mjpeg based codec (like morgan, picvideo, etc)
I wouldn' use USB and Sata HDs for capturingLa Linea by Osvaldo Cavandoli
Some combos (random) have issues with sata HDs when you grabb analogue
Searh older forum topics for more details
Lagarith vs HuffYUV, archiving and file size
By HDClown in forum Capturing and VCRReplies: 62Last Post: 30th Jul 2012, 08:08 -
Capturing with VirtualDub - File size 400GB and only 2 hours from old rec
By Diegovh1 in forum Capturing and VCRReplies: 15Last Post: 28th Jan 2012, 07:40 -
VirtualDub + Xvid: problem with file size in 2 pass encoding.
By marcinkk in forum Video ConversionReplies: 3Last Post: 8th Dec 2011, 16:47 -
VirtualDub -- XviD file size problem
By higgins327 in forum Video ConversionReplies: 8Last Post: 29th Mar 2011, 17:05 -
Please Help! Can't Get VirtualDub-MPEG2 file size down!
By dano187 in forum DVD RippingReplies: 2Last Post: 26th Jun 2007, 20:15
