I was trying to burn in Nero 6 but get this error:
File size is not a multiple of a logical block size (2KB)
DVD-Video files reallocation failed. The resulting DVD-Video might be unplayable. Do you want to continue?
Does anyone know what this means and what to do about it?
Thanks,
Rachael
You probably have a file which is zero size. This happend with old version of VobBlanker.
Thanks for the info, does that mean if I delet anything that is zero size it may burn?
If you say continue, most likely it will work just ignore the error or burn the TS folders as the last option it has. As mentioned when there is a file like the VOB is missing due to zero size but is referenced gives that error. Mine works when I say continue burn to RW if you are not sure and test.
DVD error while burning in NERO 7
By coinsdrop in forum Newbie / General discussionsReplies: 19Last Post: 22nd Apr 2009, 10:46 -
Error Nero AAC - no HC
By albo23 in forum Video ConversionReplies: 1Last Post: 17th Aug 2008, 14:06 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 20:58 -
Help. Nero error log
By R!ffraff in forum Newbie / General discussionsReplies: 7Last Post: 3rd Mar 2008, 15:22 -
I keep getting an Error while transcoding with Nero Vision 3
By kiaconcepts in forum Video ConversionReplies: 4Last Post: 5th Jun 2007, 07:35
