i followed the instructions given on the author sections..
after burning it, i tried it on my dvd and it did not work..
i know all the files r in there... since i tried it on my comp and it worked..
only reason i think is cause i did not close it..
but i have checked that finalise cd option when i start to write..
tehn i tried using the wzd mode... but every time i check that finalise cd thing, the next time i go in.. it turned unchecked again..
when i explored that cd... on the surface it said it contained only 2 megs, but when i opened it and checked the individual folders.. it gave me something like 750megs..
wdf is going on there?
some one help me. pls . i already wrecked 5 cds trying it..
sounds like it is more of a player problem then anything nero is doing, I never worry about checking finalize, I use whatever the default is in nero, it could also be that your player does not like your mpeg if it is not a standard vcd, what kind of player are you using?
Have you try to play that burned VCD in another DVD player than yours?
Sounds like DVD player problem.
Try it on APEX dvd player first that player seem can play most of format -
Agreed. I doubt closing it will help. You need to find media that works with your DVD player. One hint - once you find it, stick with that brand and type.
How close is too close
By SpectateSwamp in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2011, 22:25 -
Nero vision VCD autoplay
By Aliyans in forum Authoring (VCD/SVCD)Replies: 8Last Post: 31st Dec 2007, 10:54 -
Close GOPs
By Ar'ina in forum Authoring (DVD)Replies: 5Last Post: 23rd Dec 2007, 03:22 -
CompUSA to Close All Stores
By MJA in forum Off topicReplies: 13Last Post: 10th Dec 2007, 06:58
