OK. I have something recorded on a DVD but there are some parts I dont want to have in it and I want those specific parts to be removed. Is there a program which I can use to cut out specific parts from a movie?
Hi xXGokuXx,
You need to provide a little more detail:
What format is the stuff on the DVD? Normal VOBs etc., or recorded from a DVD recorder?
What type of DVD is it? DVD+/-R(W), DVD-RAM etc.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
You might want to read this: https://www.videohelp.com/forum/viewtopic.php?t=224833
"Art is making something out of nothing and selling it." - Frank Zappa -
Actualy, the video is saved on my computer as a .avi. Its not on DVD yet. But before I will put it on DVD I want to cut out the parts I dont want.Originally Posted by daamon
VirtualDub will do the job for you. Beware - It saves to uncompressed AVI by default, so you'll need to set it to use the same (if any) codec the AVI is in at the moment in the Video -> Compression settings.Originally Posted by xXGokuXxThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Actually, if you're doing simple cut/splicing then set both the audio and video to "direct stream copy" before saving. No need to select a compression type, no huge files and no re-encoding which takes time and causes quality loss. Alternatively, if you are converting to mpeg/dvd you can frameserve direct to your encoder. Look in the "Edit" section to your left for a Vdub editing or frameserving guide.Originally Posted by daamon"Art is making something out of nothing and selling it." - Frank Zappa
Thanks. Is there a tutorial I can use for that program?Originally Posted by daamon
No problem. There's plenty of guides on using VirtualDub in all sorts of ways - and it's fairly intuitive too.Originally Posted by xXGokuXx
These should be listed underneath the detail on the tool in the "Tools" section - just click on VirtualDub above (it's a link) and off you go...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
How can I glue these parts together? (thanks)
By ramox9x in forum Newbie / General discussionsReplies: 6Last Post: 7th Nov 2010, 12:17 -
HTPC from used parts
By redwudz in forum ComputerReplies: 9Last Post: 27th Apr 2010, 18:02 -
Is VobBlanker good for cutting parts off of VOb files???
By mabhz in forum EditingReplies: 5Last Post: 28th Jul 2008, 03:01 -
Cutting WMV into multiple parts
By craigy27 in forum EditingReplies: 3Last Post: 4th Jul 2008, 04:45 -
Cutting video to several parts without encoding (on Unix system)
By Doctor_X3 in forum EditingReplies: 0Last Post: 23rd Feb 2008, 14:23
