Hi All,
I had a two hour TV show converted from a Final Cut express project, which waas converted to a Quicktime (.mov) 21.62gb file. In order to put on DVD, I used ffmpeg, which converted it into a mpeg2, 1.86gb (.m2v) video file and a 102.1mb, (mp3) audio file.
Now, after putting them into toast 6.0 under the video tabe to burn to DVD, i am told that "Not enough free space on disk 2514367 sectors (4.8gb) are needed, 2298496 sectors (4.4gb) are available.
I have no idea why sinceboth audio and video are no where near 4.4gb.
Any help would be great, as I havent seen this specific problem addresed anywhere. Thanks.
Results 1 to 11 of 11
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
thanks Terry for the quick and kind response...
Frankly, I didnt use compressor because didnt know i could. i'm new to all this and a lot of the basics are still very murky. is that program readily available in OSX, or downloadable for free ?
thanks again. -
Compressor should have came with your legit copy of Final Cut.
Urban Mac User -
Compressor must not come with Final Cut Express, as i found the link to the program, but it's inactive.
Still wondering why I am told "not enough disk space" when the video and audio files, 1.86gb (.m2v) & 102.1mb (mp3) respectively, are under the 4.7gb limit of a standard DVD-R.
thanks. -
Originally Posted by kubrick74
As I mentioned earlier, Toast 6.0 had a bug that caused it to re-encode everything. But that was fixed in the later versions. The current version will only re-encode your MPEGs if they do not conform with DVD specs. The DVD specs are described in the "What Is DVD" link at the top left of this page. -
does NOT come with Compressor. -
I know I'm resurrecting a long-dormant thread, but a big THANKS for this! I was at the point of nearly pulling my hair out as to why Toast was suddenly telling me "not enough space" when I knew there was plenty of space on the blank DVD-R (for disc) or hard drive (where I tried to save a disc image to).
turns out this "Converted items" location was exactly the problem. I had less than 4GB available on the startup drive (which is the default location for that folder).
I'm using a much later version of Toast (version 11), but the error message is still annoyingly misleading. You'd have thought they'd make it more explicit, by saying something about 'insufficient disc space for Toast's Converted Items folder' to complete job. Please delete items or change the location of this folder in Toast's preferences). -
For the original poster, audio was also part of the problem. Mp3 was not and is not a valid codec for DVD-Video audio stream types, so it would have had to be re-encoded.
Because it was already needing to do that, it decided to re-encode the video as well, I am guessing.
And then, as you mentioned, the scratch space was probably also insufficient. Especially if the scratch space needed to hold interim files which might be less- or uncompressed.
But, btw, it would have been better to start a new thread that to resurrect such an old one.
avstodvd disk space
By nhn21 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2010, 15:16 -
not enough disk space - Adobe premier Pro 2.0
By Reggie6966 in forum Newbie / General discussionsReplies: 11Last Post: 8th Nov 2009, 03:07 -
Why am I losing so much disk space?
By Han Solo1 in forum ComputerReplies: 7Last Post: 24th Nov 2008, 20:17 -
Super eats all my disk space
By ZenSojourner in forum Video ConversionReplies: 10Last Post: 21st Oct 2007, 02:27 -
Hard Disk Space When Encoding
By Em in forum Newbie / General discussionsReplies: 8Last Post: 21st May 2007, 12:35
