Is it possible to rip some home videos from a DVD-R into Quicktime files so I can edit them in iMovie?
Any help would be greatly appreciated.
Results 1 to 13 of 13
I don't have Toast 7, but I sincerely doubt that it can rip from DVDs as well as the apps that londor suggested. Just look at all the problems folks in this forum have with deinterlacing interlaced video, converting variable frame rate encoding to fixed rate, converting between widescreen and full screen, PAL versus NTSC, etc.
Does Toast 7 handle all this stuff? If not, it isn't good for much beyond ripping chapters from iDVD discs. Then again, most iDVD discs are all a single chapter, so Toast would have to rip the entire thing even if you want just 30 seconds. -
[quote="maetel99"]I don't have Toast 7, but I sincerely doubt that it can rip from DVDs as well as the apps that londor suggested. Just look at all the problems folks in this forum have with deinterlacing interlaced video, converting variable frame rate encoding to fixed rate, converting between widescreen and full screen, PAL versus NTSC, etc.
don't doubt what you can't possibly know until you try it. -
QT will open a VOB - from there you can export it to whatever editable format you want.
You need the Apple mpeg2 component to be able to open vobs with QT and you will have problems de-interlacing video since QT can not do it.Originally Posted by videopoo
Sorry about the confusion. I had recently reinstalled Tiger (after Software Update's download of Quicktime 7.02 and Default Folder conspired to launching and crashing the Finder in an endless loop) and failed to reinstall the quicktime mpeg2 plug-in. Now I can open vobs and remember why I never bothered doing so.
Ripping DVD or Converting VOB files at a specific Bitrate - Help a NOOB.
By Corellian Corvette in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 20:09 -
Ripping a TV Series with Multiple .VOB files
By currysteph in forum DVD RippingReplies: 6Last Post: 6th Apr 2010, 02:27 -
Ripping VOB files in GK
By eliqush in forum EditingReplies: 6Last Post: 29th Jul 2009, 13:54 -
Any Free Alternative To DVD Decrypter For Ripping To Single VOB?
By DarrellS in forum DVD RippingReplies: 9Last Post: 11th Feb 2009, 00:41 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
