can anyone here recomend a good fast .mpg or .avi to vob converter and whats best program to put menus on dvd`s
Hi natty,
For MPG to VOB, the MPGs have to be DVD compliant. If not, you'll need to re-encode them to DVD compliant MPG2s. See "What Is... DVD" (top left of the page) for specs.
For AVI to VOB, the AVIs need to be encoded to DVD compliant MPG2 then authored. There are seperate tools for encoding and authoring, or all-in-one tools that do both.
There is no "best" - it all depends on what your needs and level of experience are. A Ferrari is a better car than a Mini, but not if you've just passed your test, your 70 years old and just want to drive to the shops and back. Same with video tools.
So, in short, figure out your needs and level of experience, and check out tools (link to the left, under "Lists") in these sections:
Video Encoders (MPG/DVD)
All-In-One DVD Converters
Authoring (DVD)
Then, when you've done some research, search in the forums for people's opinions and, finally, come back with more specific questions.
For me:
Encoding: TMPGEnc Plus
All-in-one: Don't use 'em, don't like 'em. Not as much control and quality can suffer but more knowledge is needed for seperate tools.
Authoring: TMPGEnc DVD Author (good as a starter), but I'm evaluating DVDLab Pro (more complex).There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
No problem. Now, get some kip - it's well gone midnight, your time...!!! And on a shool night...
Carpe diem.
As far as the all-in-ones go, the only one I can recommend with any sincerity is DivxToDVD. It will take pretty much anything you throw at it and convert to the DVD structure. No menus as yet but it's on the list of development. You can then import its output into TMPGEnc DVD Author if you wish to create menus.
As far as doing it manually, http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm might assist, as well as any number of guides in the guides section under the Convert heading (to your left). Select either MPG to DVD or AVI to DVD from the conversion feature dropdown and you'll see the guides that are appropriate.If in doubt, Google it.
Convert MKV to AVI/MPEG-2 High Quality file for HD author
By ronorkis in forum Video ConversionReplies: 7Last Post: 1st Nov 2010, 08:23 -
Can you convert/author DVD to Blu-Ray?
By zanos in forum Authoring (Blu-ray)Replies: 54Last Post: 27th May 2010, 12:50 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56
