I've got a divx-encoded AVI, a .ssa subtitle file for it, and I need to know the easiest way to make this into a DVD. I have that DIKO set, so just about every tool is included there. I looked through the different tutorials and saw how to add subtitles to a video, but those end up with raw video or another divx...I'd like to keep the steps few, so I don't lose too much quality.
Results 1 to 9 of 9
Simplest way - get subtitle workshop and convert the .ssa subs to .SRT subs. Use DivxtoDVD2 to create the DVD - no menu though. TDA can quickly add a menu with little effort required. Fast, simple, relatively cheap.
Read my blog here.
Maybe I did something wrong....but I did exactly what you said and the result is DVD files with no subtitles.
Load AVI in VirtualDub. Add .ssa with the textsub filter. Frameserve to mp2 encoder (TMPGEnc, MainConcept...) Encode to DVD specs mpeg2. Author.
/Mats -
See, I know nothing about dvd authoring so that's a bit of a problem. Is there anything simpler?
edit: virtualdub screws up the file; delays the audio by several seconds. I can't have that. -
More likely, the AVI is screwed up, or at least done in a non standard way. (VDub isn't exactly know for screwing things up...) You didn't get a warning about VBR audio stream or something when you opened the AVI, did you?virtualdub screws up the file;
/Mats -
You're not into authoring yet - it's video conversion.
Head over to the CONVERT section left, select AVI to DVD, start reading the guides. When you've managed to create a DVD compliant mpeg from youyr AVI, let's get back to the DVD authoring topic...
/Mats
Best, easiest method for converting DVD files into AVI, etc.
By pcq in forum Video ConversionReplies: 6Last Post: 30th Jul 2011, 14:13 -
Real easy question..Easiest and best avi to dvd proggy
By andrekb in forum Authoring (DVD)Replies: 3Last Post: 26th May 2011, 06:37 -
Which program accepts ssa styles? AVI -> DVD
By user2008 in forum Newbie / General discussionsReplies: 7Last Post: 13th Sep 2010, 21:19 -
5 Avi Movies to Dvd - Easiest Way Please?
By Ruudboy in forum Video ConversionReplies: 14Last Post: 23rd Nov 2008, 21:39 -
OGM/SSA to AVI
By defiancexr in forum Video ConversionReplies: 2Last Post: 15th May 2007, 00:33
