Hi all,
i am new and having trouble sorting through encoding and compression (not sure of the difference and function) and how its done. All I can do so far is convert a small Final cut Express project to a quicktime file, then burn through IDVD. However, I am trying to move on......a few questions
Are quicktime (.mov) files the same as Mpeg2 files ?
If not, are there free, downloadable programs that can convert 2 hours worth of quicktime movie to Mpeg2 ?
once converted, does the converter create a brand new file ? with a .mpeg2 extension (or something like that ?)
Much appreciated and thanks in advance as I need a little bit of handholding on this.
Um... No.Originally Posted by kubrick74
https://www.videohelp.com/glossary
There are plenty of definitions of video related terms there.
You can use a program called tmpgenc with the mov plugin to convert it to mpeg.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
You might want to read this guide - https://www.videohelp.com/guides.php?link=75 . Or, you can use the how-to menu to the left, choose convert, and then choose "mov to dvd" in the format conversion field.
occasionally larger than 255 characters -
Um... thank you, Yoda. I have already been to the glossary a few times and while it is very informational and gives the definition of those file names, the whole process is still a bit murky for me.
Also, i cant get TMPGENC to open...i think its a windows only program.
Originally Posted by yoda313 -
As far as converting Quictime files to Mpeg, then yes, the above posters are correct..Read up on the guides..
But to answer your earlier question, i'll push you into the general direction..
All video has compression (audio and video)..
A .mov file is a container for different compressions..(Mac)
An .AVI file is a container for different compressions..(PC)
An Mpeg file is a compression unto itself..The above containers support editing. Unlike the above containers, Mpeg is usually a final format that's not very "edit friendly"..
DVD's require MPEG2 video compression for compliance..
Good luck!!!
Joining HD MOV files from camera & saving as mp4; "Invalid Audio Stream"
By maskingtape in forum Newbie / General discussionsReplies: 30Last Post: 23rd Aug 2011, 12:30 -
i need help with a strange thing about frames in mpeg files...
By DjSonicx in forum Newbie / General discussionsReplies: 2Last Post: 24th Aug 2009, 14:22 -
How do I join two avi files without re-encoding the whole thing?
By jpate86 in forum Video ConversionReplies: 6Last Post: 10th Jun 2009, 06:35 -
Sony Vegas 7 doesn't let *.mov & *.avi files be imported into project..
By koldun in forum EditingReplies: 5Last Post: 1st Jul 2008, 15:04 -
Latest Version 2.5 & Problems with mpeg2 (files become too big) + AVI2M
By bc82 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 29th Jan 2008, 08:31
