I'm trying to do a PAL to NTSC conversion on a stereo AC3 I have, but can't get anything to work. I've tried both AC3 Machine and BeLight and neither work. AC3 Machine does nothing when I hit the compile button, and BeLight looks like it's giving me a conversion, but the new file ends up still being in PAL format. Can anyone help?
I'm lost why you are trying to convert the AC3? Why are you not just extracting it and then working on the Video?
If it is only AC3 audio why not just use it? If it is a PAL movie look in the guides to convert to NTSC.
Good Luck
Some links:
https://www.videohelp.com/forum/viewtopic.php?p=1368007#1368007
https://www.videohelp.com/forum/viewtopic.php?t=261056
Edit: The first one came up with a google search. -
I've already converted the video using this guide: https://www.videohelp.com/forum/viewtopic.php?t=222898
I'm now trying to convert the audio, but can't figure out how. I've tried using the audio as-is, but it's out of sync, so I need to convert it to match the video. -
Re-do the video using the DGPulldown method. Then you don't have to much around with the AC-3 audio. This is best if you have 5.1 AC-3 but if you only have 2.0 AC-3 then first convert the 2.0 ac-3 to a 16-bit 48K Stereo PCM WAV audio file. Then use BeSweet to change the FPS going from WAV to WAV then convert the corrected-for-length WAV back to 2.0 AC-3
This is easy with a stereo 2.0 AC-3 audio track. It is harder with 5.1 AC-3 as you have to deal with 6 different WAV files.
DGPulldown works well and does not require a change in the audio.
See this here thread ---> CLICK HERE
Good Luck
How you determine it is PAL?! Audio has not such a formating as PAL or NTSC.but the new file ends up still being in PAL format.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Convert PAL to NTSC?
By killerteengohan in forum Video ConversionReplies: 32Last Post: 7th Feb 2012, 12:33 -
Convert NTSC AC3 (29.970) To PAL
By DeathStalker77 in forum AudioReplies: 0Last Post: 26th Apr 2010, 22:09 -
PAL AC3 to NTSC AC3
By USiT2009 in forum AudioReplies: 6Last Post: 6th Sep 2009, 17:55 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
