I have a few (Commercial) DVDs that are backed up on my computer and they are around 4.1GB. I usually compress DVDs using DVD2OneX, but those are always about 7GB. Since the blank DVDs are 4.3GB it seems like it would work.
Can I just drag the VIDEO_TS and AUDIO_TS folders to Toast and burn? Or is there some sort of protection on it?
Sorry if this has already been asked but I couldn't find anything on a search.
If you were able to get them onto your har drive, any copy protection problem is already solved. Yes, you may burn them without further compression.
compress DVD video
By avextraxjp in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2008, 19:04 -
compress ps3 to 1 dvd ?
By pcb in forum Newbie / General discussionsReplies: 2Last Post: 26th May 2008, 12:58 -
Looking for best way to compress dvd backups
By Wolfsrudel in forum Video ConversionReplies: 8Last Post: 2nd Jan 2008, 14:36 -
how not to compress with tmpgenc dvd author 3
By achtungpop in forum Authoring (DVD)Replies: 6Last Post: 1st Dec 2007, 07:59 -
How do you compress several DVDs in to one DVD R?
By Baldrick in forum Newbie / General discussionsReplies: 1Last Post: 29th Nov 2007, 04:50
