It seems everytime I use dvd shrink to backup video files, somewhere in the middle of the process I get a generic blue screen on my computer that says physical dump,and I have to shut my computer down.Why is it doing this???
Computer problem seems likely. Unless it is only happening on one Movie then it would be the movie itself.
Could be bad memory, CPU overheating, Spyware/Virus infestation. Easy to test overheating theory. Pull the side and look at the CPU heatsink, is it clean or clogged. Try shrink with the side off and a fan blowing in. -
also, if you overclock your cpu or RAM, set defaults in BIOS, try shrink again. things that might help from link below have helped me at times
http://www.network54.com/Forum/thread?forumid=336827&messageid=1101539218&lp=1124233612Tam
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
