  1. Hi all,
    I bought the old Hyundai DVD player with 4 movies out of the newspaper. I've had it a while noe and it's great. But, I've lost the remote control and I can't find the universal code for the universal remote i have. I'm wondering if it could be under a different manufacturer's name. Anyone know which one I should use?
    Thanks in advance.
    Al.
  2. Member NoFace's Avatar
    Jan 2005
    wherever I am
    I had the same problem with a little sony tv my kids have. Did a Google search for "universal remote codes" and found many sites that list all the codes. Good luck.
    occasionally larger than 255 characters
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Google is your Friend
