I really hope somebody can help. I have spent 1 ˝ days reading, learning and playing with TMPGEnc 2.00. While I have learned a lot and have actually made progress I am not getting the right results. I am at a point where I am concerned that I have the quality as best as I am going to get.
Here is my problem:
I have a PAL SVCD and want to simply convert it to an NTSC SVCD. I am able to convert and burn test CD’s which play fine but the quality looks like a VCD. The PAL SVCD is a near DVD quality but after I encode, burn and play it shows a lot of artifacts/pixilation and some scenes seem a bit jerky. I load TMPGEnc and setup the output to NTSC SVCD. The original file is 4:3, 25 fps, 720X576. Is this problem occurring because the default NTSC SVCD outputs to 29 fps, creating all of my headaches? Should I change the default output fps? Is PAL to NTSC more complicated? Any other setting recommendations aside from the ones in the How-To’s here on VCDHelp?
Hope I provided everyone with enough information. If you need more please let me know.
Thanks everyone any help would be appreciated!
Results 1 to 1 of 1
Encoding .Avi to Svcd?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 13:40 -
Encoding VIDEO_TS to mpeg-2 SVCD
By phamtom in forum ffmpegX general discussionReplies: 6Last Post: 27th Apr 2008, 15:05 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56
