Hi everybody, I have an analog camcoder and would like to capture what I have in tape and save in cd so i can view in my standalone dvd player. I am new in this and don't even know which hardware i need to get nice cd's. My computer is Compaq SSF PIII 600mhz, 128MB ram 20gb HD.
thanks in advance to any advice!!!
Pablo
your computer is ok for what you want to do but you may want to pick up another hard drive, 20 gig would be ok just make sure it is a 7200 rpm model, you will need a capture card, I used a $40 tv99 capture card for over a year before upgrading to an ATI aiw, which is another option if you want to spend a little more and get a better gaming card at the same time and the price has fallen on these to around $100. after getting these things come back and read the guides here and give it a go, any problems you know where to come.
Thanks, maybe I will need another pc because this one is a small form factor and that means that only have space for 1 hd; unless I can swap mine with a 40GB or more? What about the software?
Pablo -
Generally it is better to capture to a different drive than your os is on, less dropped frames at higher resolutions. But if you are limited by case size than try a bigger drive. But a second drive is a much better way to go.
For software, a good way to go is to capture the video to an AVI file using Virtual Dub (Free), encode it to MPEG using TMPGEnc (Free), and then write it to a cd using Nero (Demo Available). If you have limited HD space, then you can use a program that captures directly to MPEG such as CinePlayer DVR (Demo Available), but that will result in poor video quality.
Sorry for the delay!
I will try all your advices as soon as I can buy a bigger drive. I am also considering using external scsi drives.
Thanks all
Happy New Year!
Analog capture poll
By goggy59 in forum Capturing and VCRReplies: 3Last Post: 4th Jan 2009, 19:28 -
Best USB Analog Capture - Under $400?
By pjtgrizzly in forum Capturing and VCRReplies: 4Last Post: 31st Dec 2008, 16:45 -
new system capture card analog and dv
By rikit in forum Capturing and VCRReplies: 0Last Post: 27th Nov 2007, 19:44 -
Analog video capture in Vista.
By Frogged in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2007, 09:47 -
Analog to Avi capture card
By ni-mh in forum Capturing and VCRReplies: 0Last Post: 25th Jul 2007, 16:16
