I am doing some editing work for a friend, his camera is an ntsc camcorder dvd. ie: he has a mini dvd disk that the camera records onto. the files are 'vob' files, meaing they are dvd files. I have looked at toast, and although i don't know much about it, it seems to be dvd 'burning' software, not copying software.
The bottom line is i need to extract certain footage from the disk so that i can put it into the show reel i am making. On a pc i can do this easily with a number of programs such as procoder and dvdshrink. On a mac which i am not familiar with, i have only be able to find 'mac the ripper' now for it to work it shouldn't be shutting down every time i try to rip something from the dvd.
if anyone can help me out i would be in your debt.
unless you know of another mac program i can use, that will convert the 'vob' files to 'avi' for use in final cut pro
Mark V
10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D -
Don't convert VOB files to Avi--Final Cut Pro won't like them.
Convert either to DV stream, or at the worst, QT .mov.
look here:
ffmpegx,
just substitute "DIVX" with "DV Stream"."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Its not freeware , but inexpensive..
CINEMATIZE..does exactly what you want
It marks in and out points within CSS-FREE vobs and creates either a NEW STANDALONE FILE (in MPEG-2 or some lesser compressed file)
or a Quicktime Refrence MOVIE
Caveat: you must have quicktime pro and the mpeg-2 quicktime component installed for cinematize to work -
Note, if Mac The Ripper will not put these files on the Harddrive first, try
DVDBackup -
Originally Posted by dcsos
Thanks for the help. Hopefully my friend that i posted this help for gets to do what he needs to get his editing done.
Mark V
toast 7 can do this for you.
you can browse the DVD and select individual titles or chapters, and then convert into DV for editing and/or reburning to a new disc.
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
What is the best editing software for editing head
By sonic12345 in forum EditingReplies: 1Last Post: 4th Jul 2010, 21:05 -
Editing as a career / editing freelance jobs
By ayim in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2010, 21:31 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 07:06 -
DV Editing
By m baqar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Apr 2008, 01:48
