Hi all.
I have a questionabout ffdshow and virtualdub. I want rip a wav file from an AC3, GSpot tel me that ffdshow is ale to decode but in VD, in full processing mode it can't (tag2000).
Must i install AC3ACM or it's possible to use ffdshow ?
If you want to convert an ac3 file to wav, you could use virtualdubmod to direct stream copy the file, and then use besweet (w/GUI, unless you're the command-line type) to convert it to wav (you could use the azid1 filter for this).
occasionally larger than 255 characters
What is FFDshow?
By terrypin in forum DVD RippingReplies: 11Last Post: 7th Apr 2010, 17:26 -
using ffdshow with??
By uglijimus in forum Video ConversionReplies: 7Last Post: 18th Aug 2009, 23:55 -
diff. btw ac3, divx, ffdshow codecs???
By geronemo in forum Video ConversionReplies: 0Last Post: 18th Nov 2007, 15:25 -
ffdshow - AC3 or LCPM?
By AuroEdge in forum Software PlayingReplies: 6Last Post: 7th Nov 2007, 16:26 -
What is ffdshow and should I be using it?
By Hank Kinsley in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2007, 00:52
