Hi,
I have a whole stack of music video clips that I like to play. The problem is that they all vary in volume so I am constanly turning my volume up and down.
So my question is: Is the a program I can run these trough to make all the volume levels the same?
Cheers,
Taark
yes - normalize then ,,, tons of software can do this to mp3s ..
I don't know of a single program that would make all the volume levels the same, but it wouldn't be that difficult to demux them all, adjust the volume of each clip in an audio editor and then remux them. It would probably be more time consuming that just finding a program you could dump them all into and say "make the volume the same", but if you can't find a program like that...
Hello Taark, I too have the same problem, Hundreds of mpg-2 files all varying in audio volume.
If you too have mpeg2 files, you can go through the demux, process audio, then remux, and hope that the audio stays in sync, or you can get DVD authoring software such as Ulead DVD Workshop2, or Sonic's DVDit5 or 6 (both of which are not that great). These software quthoring packages allow the audio to be adjusted for each clip.
You could also wait till Tsunami software's DVD Author Pro is released later this month. Better softwae, easy to use, and according to the TSUNAMI site, this software will also allow for adjusting the audio volume of a music video clip. :P :P :P
Might also work with mpeg-1's
Doc_BReach for the Starz -
I can make you a batch that will demux, adjust the volume, and multiplex back..
BUT.
It can only be done with MPEG-2 files.. so if you have mpg-2 files, tell me (Via PM), ill make it. it's really simple..
Help - Raising Volume Levels on M4V Files
By mandarpowale in forum EditingReplies: 5Last Post: 15th Nov 2010, 11:25 -
how to adjust volume without re-rendering?
By dora in forum AudioReplies: 3Last Post: 22nd Jan 2009, 01:07 -
Using HC gui 0.23 how cam you adjust output mpg video brighness levels
By oavs in forum Newbie / General discussionsReplies: 13Last Post: 18th Oct 2008, 11:02 -
adjust the volume
By volam in forum EditingReplies: 9Last Post: 1st Mar 2008, 19:19 -
Adjust audio volume with FairUse Wizard or later
By 2dpikke in forum DVD RippingReplies: 5Last Post: 5th Jul 2007, 23:40
