Can someone help me!
I try to make VCD pal Subtitle movie with TMPGnc.
But I can't make the movies under the 700mb.
Is there a TMPGEnc Templates for this?
My DVD player JVC XV-525 do not play SVCD only VCD pal!
Results 1 to 23 of 23
Just split your file and burn it onto 2 cds!
I only dream in black & white...
MSN: paschendale@gmail.com -
I DON`T want to spilt my movie!
I want it fit on 1 cd...itīs only 713mb.
Can some one tell me how I do it?
well if you are useing nero to burn your movies...you can fit 740mbs in a 74 min CDR and 800mbs on a 80 min CDR so you dont have to split if you use nero
I have Nero 5.5.6.4...can you tell me how I can fit my movie on 1 cd with nero?
Nero itīs new for me...I always use easycd 5.0
Please help me.... -
well go here and read the guide:
http://www.vcdhelp.com/nero.htm
and remember in the option select iso level 2 okay
almost forgot....Is there a nice TMPGEnc Templates that I can use to make my VCD pal?
I want to make VCD pal with subtitle and the movie have to be under 800mb...I lost the special TMPGEnc template (to fit movie on 1 cd)
can you find me a new one? -
thank you.
But what tamplates can I use..the SeVCD or the SxVCD?
my move is almost 97min. -
Glock, you wont' be able to use the SxVCD since your DVD can't play SuperVCD, try using the SeVCD instead, it is more compatible with VCD standards.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
You can't have subtitles using TMPGEnc.
and ohh yea Glock please read this:
https://www.videohelp.com/phpBB/viewtopic.php?topic=71298&forum=3
Dhruv, yes you can make subtitles if you click on this and read the page....http://www.vcdhelp.com/subsvirtual.htm
Sefy...
what template can I use SeVCD Basic or the SeVCD Enhanced?
Please help....
You can use both, the Templates that usually give people prob is the SxVCD ones
Best Regards,
Sefy Levy,
How to Sync subtitles from dvd PAL to MKV 23,976.
By axl70 in forum SubtitleReplies: 7Last Post: 15th May 2015, 07:38 -
ntsc -> pal subtitles [solved]
By etvideob in forum LinuxReplies: 0Last Post: 30th Jun 2009, 04:33 -
Subtitles and NTSC -> PAL Video Conversion ?
By shotokan101 in forum SubtitleReplies: 14Last Post: 5th Jan 2009, 20:39 -
Ripping PAL Teletext subtitles from a DVR-MS file
By boulder in forum SubtitleReplies: 0Last Post: 8th Aug 2007, 15:23 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
