I'm having problems with divx... I can't seem to get video when I encode, just audio. I'm using the multipass, 1st pass setting and no video just audio! I'm also using virtualdub 1.6.9
Is there a way I can fix this?
It's annoying!
chrisyroid
Maybe it's just me, but I've had problems with the latest versions of VD. You might try an older version. I generally use VD Mod, which is 1.5.10.
Hmmmmm... *scratching chin* I allready have vd mod 1.5.10 and I tried it and does not work, I just come out with the same results. Plus, I tried all of my downloaded versions 1.4 - 1.6 ( I'm a pack rat ) but still does not work!
chrisyroid -
Do you have the same problem on single pass? I don't believe you can view the first pass results, if that's what you mean.
If the finished second pass isn't viewable, maybe reinstall the Divx codec or try Xvid and see if it does the same. -
During the first pass Divx is only looking to see how much bitrate each frame needs (performing a constant quality compression). It saves information about the frames in a file in its temp folder, it doesn't have to save the actual video.
I think there used to be an option to save the video from first pass. But it could get very large because it is generated at a low quantization value (high quality). -
ok, I encode the video in multipass 1st pass then encode the same file in multipass 9th pass then I should have a playable video but I don't!
what's going wrong?
chrisyroid
x264, point of 1st Pass encoding?
By Sephisto in forum Video ConversionReplies: 50Last Post: 18th Apr 2012, 01:13 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 06:59 -
1st and 2nd Pass with VDub/VDubMod when cutting out frames.
By Chakra in forum Newbie / General discussionsReplies: 20Last Post: 11th Mar 2011, 17:45 -
Removing subtitles, running 1st pass again?
By moviebuff2 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 06:20 -
Virtualdub, 2pass - 1st pass statsfile not found
By kidcash in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2007, 03:05
