Usually when I edit video I cut it using Virtual Dub.
I have one DV movie divided into several files (about 1,8 GB each).
They are type-1 DV's.
For some reasons I want to change them to type-2 DV's but still keep the 1,8 GB size per file (of course as a result I will get more files).
How can I do this without loosing any quality?
I downoladed "DV type-1 to type-2 converter" and created type-2 files, but they are too big (they exceed 1,8 GB each). I was thinking about opening those files in Virtual Dub and selecting direct stream copy in audio and video. Is it the proper way? Won't that affect the video?
I checked: recent versions of VirtualDub (I used 1.6.9) create type 2 files out of type 1 if you use Direct Stream Copy for both the audio and video.
AVI files normally have explicit audio and video streams. When DV is captured to a type 1 DV AVI file the multiplexed (as received from the camcorder) video and audio are saved as a single video stream. Some programs understand the audio is in the video stream, others don't. A type 2 file has a second copy of the audio stream explicitly saved as an audio stream.
When VirtualDub 1.6.9 Direct Stream Copies the audio from a type 1 DV AVI file it automatically copies the audio from the video stream and saves it as an uncompressed PCM audio stream. -
thx
ps. i had an old version of virtual dub that couldn't read audio from type-1 files. now everything works perfect ...
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 21:24 -
MP4 Stream Multiplexing Type Compatibility
By datbates in forum Video ConversionReplies: 0Last Post: 27th Jun 2011, 01:49 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
Stream type mismatch - 19023 with DVDit Pro 6 Redux
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 21st Apr 2010, 17:24 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 20:16
