I've an odd problem with DVD Decrypter (Ver. 3.5.4.0) that has just recently started happening.
If I burn a ripped DVD using Nero (with the same settings that I've always used) when Nero finishes I click 'Done' and it auto-ejects the DVD, at this point I've been in the habit of closing Nero and then loading DVD Decrypter, using it to close the DVD tray and then waiting for the file parsing to list the contents of the DVD, in so doing I'm performing a verification that the DVD was burnt correctly. I've done this for in excess of 250 DVDs that I've burnt with movies on them and it's always worked. But what has started happening recently, and has happend every time since it started happening, is that when I reload the DVD tray containing a DVD that has just been burnt with Nero, DVD Decrypter fails to parse the file structure and does not list the files. Odd. If I then insert another DVD (with a movie on it) DVD Decrypter lists the files as normal. Now this would suggest that the burning failed somehow, BUT if I reboot my PC and try the same DVD that was just burnt (and usually hasn't even been taken out of the DVD tray) after the reboot DVD Decrypter parses the files and lists them as usual. The DVDs which have had this strange behaviour all play fine on my standalone DVD player too.
Has anyone else had this problem, or has anyone any idea how I can fix it?
None of my equipment has changed I've installed no new hardware, nor am I using any DVD software in the ripping, compressing, burning stages that I haven't used a hundred++ times.
The only new software I've installed on my PC is as follows:
Google Desktop v.2 beta and uninstalled a few days later.
Epson Stylus Photo R300 software and drivers
GhostScript and GhostScript
Broadband Speed Tester
MySQL Administrator 1.1.2
MySQL Query Browser 1.1.14
But why would any of these cause the DVD Decrypter problem which I'm having?
Many thanks,
MS
What happens if you close the DVD tray after closing Nero, then start DVD Decrypter a few seconds later ?
If in doubt, Google it. -
Thanks for your reply.Originally Posted by jimmalenko
I found Nero's 'do not eject DVD after burning' preference and turned it on. When the DVD finished burning, it didn't eject, and I closed Nero before loading DVD Decrypter which parsed the files and displayed them correctly.
It's working but any ideas why this behaviour has happened? And why should a DVD disk try open and then close make any difference?
Thanks again. -
Maybe it's just the "close tray" command in DVDDecrypter that's causing some sort of timeout issue within DVDDecrypter or something ?
Maybe you updated to a later version of DVDDecrypter ?
Lots of maybes, but since the program is not going to be updated ever again, it's probably just as easy to forget about why it wasn't working, and focus on the new method that does work (in other words, I don't the exact cause of the issue, but I don't think it's worth worrying about either since a simple workaround has been established).If in doubt, Google it. -
I didn't update DVD Decrypter recently, I've been using the latest and last version since the day it was released. I agree it's not a problem and I have a method of making it work, I'm just interested in why this strange behaviour should just start happening after using it so consistently in the same way with no problems and with no obvious reason why it should happen.Originally Posted by jimmalenko
Thanks for your help.
Odd problem on file size.
By daz1976 in forum Video ConversionReplies: 4Last Post: 23rd Mar 2009, 16:35 -
Need help with odd problem with erasing/recording DVD+RW
By fdm2000 in forum ComputerReplies: 17Last Post: 3rd Nov 2008, 18:02 -
Help with odd problem recording/erasing DVD+RWs
By fdm2000 in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2008, 08:24 -
DVD Decrypter Problem
By WuPhilly in forum Newbie / General discussionsReplies: 14Last Post: 17th May 2008, 16:28 -
Problem with DVD Decrypter
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 4Last Post: 31st Oct 2007, 13:01
