Further to my other post elsewhere:
If the field order of "lower field first" applies to all my existing AVIs, can I assume it is correct to keep that field order the same throughout an authoring project, even though some authoring utilities default to "upper field first"?
Thanks ~ John
I'm not sure what you mean. Do you mean if you load several AVI clips into an editing app and some of them are identified as TFF and some BFF, although you know they're all BFF?
Encode or author them to what you know they are.
This does bring up an interesting question though, what if you have clips captured using different capture. Let's say some are from a ADVC which would be lower field and others from a PCI card which are upper field. Wah tdo you do then? Punt? -
Most editing software lets you specify whether each source clip is TFF or BFF. Because they sometimes guess incorrectly.
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 03:12 -
what is the meaning of these ? frame based, lower & upper field first.
By khalid81 in forum EditingReplies: 3Last Post: 15th Jun 2009, 11:27 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 22:54 -
PAL to NTSC -- Upper or Lower field first?
By hurricane1951 in forum EditingReplies: 2Last Post: 1st Aug 2008, 05:39 -
AVCHD - upper fields or lower?
By tat2jr in forum Video ConversionReplies: 8Last Post: 29th Jul 2007, 11:38
