Hey guys, hoping someone here might have some suggestions to my probs. When im trying to cap tv shows from my cable box I find that I can't maintain a steady 25fps. It will start out at 25fps then after about 2-3min it'll drop to 24.99757 and stay there abouts which in turn causes me to drop like 3-5 frames from a 9-13min clip.
My System and Settings:
Athlon 900
384meg pc-133 sdram
WinXP
40gig 7200 ATA 100 IBM HD
SBLive Value
Pinnicle pctv card
Capture settings
Vdub with HuffyUV (predict best)YUY2 (tried all 3 settings)
352x288 25fps PAL
Card hooked up to cable box via composite plug
Its not a major frame drop but I would still like to drop no frame at all if possible and maintain 25fps. I don't think its winxp cause same thing happened in win98.
I've tried the test the capture without the audio but I still drop the same amount of frames
Hmm I just tried the suggestion from someone elses post to uncheck "disable windows write buffering" and I only dropped 1 frame but my fps still dropped to 24.99 etc
Any suggestions appreciated![]()
i drop 20 frames per 60min, always have and looks like always will. with vdub and avi_io.
iuvcr though is different, it will drop 3 or 4 frames in a chunk or none at all but audio stays in sync so no real problem there.
AverMedia HD DVR - Frame drops in live playback
By Anonanon in forum Capturing and VCRReplies: 3Last Post: 1st Mar 2012, 02:11 -
Joining 2 TS streams produce glitch and frame drops
By arminio in forum DVB / IPTVReplies: 8Last Post: 7th Jun 2011, 03:30 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
Camtasia Error : "Unable to write AVI file frame"
By ShinuMirai in forum Newbie / General discussionsReplies: 8Last Post: 11th Oct 2009, 16:19 -
batch WMV to AVI that will maintain video bitrate and frame dimensions
By chief1972 in forum Video ConversionReplies: 2Last Post: 27th Dec 2008, 14:17
