I am using the above program and have a problem where as I have extracted a movie that I recorded with my TV DVD recorder. I used DVD decryptor to decode the movie and I got 3 parts. All are .vob files. At first I loaded all 3 parts and previewed them and they all played with sound perfectly. Both while in the Editor and in the storyboard.
Then I was attempting to learn how to clip out unwanted peices so as to reassemble it as a whole again. Anyway after several false starts and re loading the program I found that part 3 will play both video and sound when in Edit and you click the clip, but when you put it in the Storyboard it wil only play video. I have no Idea what I did to cause the problem. SO I deleted all parts and decripted it again with 2 different decryptors and I always get the same problem only part 3 wont play the audio whil in the edit mode. I also assembled the whole video but when it starts playing with ANY program and gets towhere part 3 started it has no audio.
Also I tried reinstalling the program, and rolling back the computer to befor I installed it. Part 3 will play on any other player with audio working fine.
Any Ideas?
Results 1 to 1 of 1
Any Win 98SE gurus here? Sound card problem =(
By sdsumike619 in forum ComputerReplies: 16Last Post: 26th Sep 2011, 20:32 -
Bad sound quality from avi's to DVD w/both Toast or XiliSoft DVD Creator?
By NoMoPackers in forum MacReplies: 7Last Post: 2nd Apr 2009, 03:57 -
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 10:43 -
Win DV sound prob
By prcole18 in forum Capturing and VCRReplies: 7Last Post: 14th Jul 2008, 15:07 -
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 14:26
