Is there any program other than TMPGenc. My computer is to slow to use it. I only have a pentium celeron 366 mhz.
I need a program that can convert .wmv to mpeg1.
Thanks,
The Unknown
There are things known and there are things unknown and I'm The Unknown
u will need to use tmpgenc and this is how to make it run faster-
Someone else might know but i do know that encoding asf and wmv formats in tmpgenc, it does go slower but here is how to speed it up-
Encode to pal for one, that way u can drop the frames from 29.97 to 25
Also, make sure your res is at 352x288 and all methods are set to pal; if anyone is set out of pal and in ntsc, the vid and audio will go out of sync.
Motion search precision set to lowest quality.
For vcds- there really is not very much quality difference compared to lowest quality and highest quality.
In advanced tab, make sure no filters are turned on and in quantize matrix, uncheck soften block noise
(YOU DONT NEED THIS ESPECIALLY FOR WMV FILES SINCE WMV FILES ARE ALREADY SLIGHTLY BLURRY TO GET RID OF BLOCKS!)
ShiZZZoN PzN
Everyday is another payday and I am one step closer to becoming the one.
Convert audio file og WMV HD video
By karebo in forum AudioReplies: 2Last Post: 27th Aug 2011, 09:15 -
Cannot convert 7.5 GB mkv file to wmv?
By killazys in forum Video ConversionReplies: 1Last Post: 17th Feb 2010, 19:07 -
wmv file wont play nor convert
By excitezone in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2007, 12:56 -
May I know which software can convert a wmv or asf file to better viewable
By sniper in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 12:22 -
Trying to convert WMV to MPEG1 on a slow processor
By Gooey in forum Video ConversionReplies: 2Last Post: 21st May 2007, 03:59
