I'm not sure if this is the correct title heading, nor could I find anything else in the forums that relates to this. I would like to combine several video files into one video file, but NOT one after the other. I would like to have them all displayed at once, similar to how the older versions of windows media player used to be able to have multiple instances of video running simultaneously - the newer versions of wmp no longer support this. I've created a collage, but had to take each individual video file, split it into its component frames and create new frames by cutting and pasting into photoshop. Creating 30 frames for each second of video is extremely frustrating and time consuming, even using macros. I'm not quite so concerned about combining the audio streams, as I'm probably just going to play background music. Any help that you can provide would be much appreciated. Thanks in advance for ANY help that you can give.
Results 1 to 12 of 12
Well, if you have a decent editing software, you can import your video tracks and then scale it down, such that all of them fit on the screen.
standard stuff for vegas and premiere ..
often referred to the Ken Burns effect ..
there is a specific plug in for vegas that will even do the whole thing for you automatically .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
man - i can always count on this forum for INCREDIBLY fast answers!!! Thanks so much - I will give it a try!!!
Maybe you want to do multi screen effx?
Premiere and vegas do this also
if you want the ken Burns effect
about dot com has tutorials for
iMovie
Ulead
Pinnacle
Premiere
http://desktopvideo.about.com/od/advancedvideoediting/ss/kenburns_ro_5.htm -
@ scorpio47: Just in case you end up using Adobe Premiere:
www.wrigleyvideo.com/videotutorial/tutdes_quadpip.htm
All tutorials at: www.wrigleyvideo.com/videotutorialThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by p_l
www.vaast.com"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
This can also be done fairly easily in AviSynth using the Resize, StackVertical and StackHorizontal commands.
Buy My Books -
Originally Posted by BJ_M
Umm... I guess you mean VASST, but it's $25 for something that comes free with most other NLE's, for example Ulead VideoStudio.
Ulead probably has the best built-in Ken Burns effect on the Windows platform. In Ulead VideoStudio 8, load a photo onto the timeline. You then access the Ken Burns effect this way:
1. First, be sure that the photo is selected (click on it until it is highlighted in red). You will then see the settings area for the Image tab to the left of the preview window will now display the Pan & Zoom radio button.
2. Click the button to activate the presets selector.
3. Select the down arrow and scroll through the 14 preset pans and zooms. If you don't find what you want, use the Customize Pan & Zoom button to create your own.
4. Click the Play button in the Preview window to test your Ken Burns effect. -
yes -- but ulead is no match in any other respect ..
Making an "overlay" for live video
By SimoneA in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2010, 07:30 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 18:49 -
Making a Toast "DVD Video" Disc
By albloom in forum MacReplies: 5Last Post: 22nd Apr 2008, 11:45 -
making a "music video"
By amikhchi in forum DVD RippingReplies: 8Last Post: 31st Dec 2007, 22:00
