I need some advice converting Real Audio/Video RM files to MPEG using EO Video.
I tried converting some files, but the resulting MPEG video seems darker and
muddier than what is played in the RM Player.
Is there anyway to brighten up the colors?
Another problem I have, is that when trying to play the resulting MPEG in Windows
Media Player, the picture is squashed down. I don't know why this is happening.
When I do 'Source Info' in the RM player I get:
Code:Stream: RealVideo Stream - Single Rate Max Bit Rate: 225.0 Kbps Stream: 0 audio/x-pn-multirate-realaudio logical stream MIME type: audio/x-pn-realaudio Max Stream Bit Rate: 32.0 Kbps Audio Codec: 32 Kbps - RealAudio (RealAudio G2) 22050 Khz Stream: 1 video/x-pn-multirate-realvideo logical stream MIME type: video/x-pn-realvideo Max Stream Bit Rate: 193.0 Kbps Dimensions: 352x240 Encoded Frame Rate: 30.0 fps Video Codec: 193.0 Kbps (RealVideo 8)
In EO Video, output video options given are:
- Output size
- Picture fitting
- Frame rate
- Frame Intervals
- Quality Bit/Rate
How should I set this up in EO Video, so I get the best picture possible after conversion?
What bit rate, constant, variable, etc..?
Results 1 to 1 of 1
Video/audio TS files convert to an uploadable MPEG video
By Prizm007 in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2011, 15:30 -
converting .rm real media files to .avi or .mpeg
By tilopa88 in forum Video ConversionReplies: 5Last Post: 25th Jul 2009, 10:45 -
MPEG Streamclip, Audio But No Video!
By EZ-Fan in forum Software PlayingReplies: 3Last Post: 23rd Dec 2008, 12:31 -
FlYDS capture REAL-TIME MPEG-2
By goal in forum Capturing and VCRReplies: 3Last Post: 27th Feb 2008, 05:08 -
converting a ram (real video) file to mpeg problem
By Bamahusker in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 22:35
