    Feb 2005
    finland
    i istall this software 'startup control panel'
    i want to unstall it but i cannot find it in the add\rmove.
    i went to the software sie and found this
    'Use the Add/Remove Programs control panel -OR- delete Startup.cpl from your windows system directory. In either case Control Panel can't be open (If you are using Add/Remove programs, close the Control Panel window before hitting Add/Remove).'
    is not in add\remove and i do not know where to locate the windows system directory to delete.
    Apr 2004
    Miskatonic U
    right-click on My Computer and select Search... Choose All Files and Folders, and then type startup.cpl in the 'All or Part of Filename' box. Click on search. Once it finds the file, highlight it and delete it.
    Otherwise, look in c:\windows\system or c:\windows\system32 (assuming your windows folder is on the c: drive)
    Read my blog here.
  3. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    if something is not showing up in "Add/Remove Programs", search your hard drives for ALL files named "sysoc.inf".
    Open all of these files with word pad and DELETE every instance of the word "HIDE", then save the file.
    Go back to "Add/Remove Programs" and see how much more stuff shows up now....
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
  4. Member Soopafresh's Avatar
    Jan 2004
    If that is from http://www.mlin.net , it is a really good app.
