Is any option in TMPGEnc 2.5 or 3.0 Express, for file spliting when encoding video from avi to mpeg.For example, when encoding some avi file to DVD format when final mpeg file will be about 13 Gb, I want to set the file splitting for about 4,2Gb. In that case the final product will be three Mpeg files with approx. 4,2 Gb and ready to edit with some DVD authoring program and burn to three DVD discs.Since now I can't see such option in both of TMPGEnc version.
Regards.
QUALITY HAS A NAME
humm,, why not select the source range before encoding... or if you already got the mpg... use tmpegs mpeg tool & cut the files down to size...
COOKIEEE!!!
Splitting a .TS file in half
By danielmak in forum MacReplies: 4Last Post: 1st May 2011, 00:19 -
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 16:44 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 08:18 -
Inaccurate file splitting
By Blå_Mocka in forum Newbie / General discussionsReplies: 11Last Post: 13th May 2008, 04:19 -
Splitting avi file
By tryst1 in forum EditingReplies: 2Last Post: 15th Nov 2007, 03:33
