    Jan 2005
    North America
    First of all, I cut of the mpeg2 file with mpeg-vcr.
    I then run a batch file the dose the following:
    • bbdemux (mpg into elementary streams) -->
      then either using besweet or ffmpeg to transcode the audio (m2a) to AC3 -->
      multiplex (using the new audio and origional demuxed video) w/ mplex -->
      then author with dvdauthor
    Would this method inherently induce audio sync problems?
    Would purchasing TDA w/ the ac3 plugin (to use TDA to transcode) be worth it?
    USA
    Mpeg-VCR is a good MPEG editor, shouldn't usually cause sync problems. MPEG video is always a little risky to edit, depends on the quality of the original video and how and why it was edited. It's best to monitor the sync after each step in the process to see if there is a problem. This, before you burn it.
    I doubt the AC3 TDA plugin would decrease the likelihood of sync problems over a stand alone AC3 encoder. It would be simpler, though.
    You also might try adding the AC3 back in during the authoring stage and let TDA mux it instead to see if that helps.
    Jan 2005
    North America
    Thanks redwudz...
    I kind of ask because I get something like this from mplex:
    (Used DVDAuthorGUI to get a log of what mplex spits out)
    Originally Posted by DVDAuthorGUIlog.txt
    INFO: [???] STREAM e0 completed @ frame 4616.
    INFO: [???] STREAM bd completed @ frame 4814.
    Is this normal?
