Can anyone help me Im trying to back my movies up from hard drive using nero but am having no luck cananyone help me
It might be easier to use DVDDecrypter and DVD Shrink.
What format are the movies in? If they are folders with AUDIO_TS and VIDEO_TS, then just open Nero and select DVD Video. Drag the contents of your VIDEO_TS folder into the Nero VIDEO_TS folder and select 'burn'.
If they are not in that format, you may have to author the MPEG-2 files or encode them to DVD compliant files before you author them.
Take a look to the left for 'What is' DVD to see the DVD specifications. <<< -
Hows about providing alot more information concerning what you are doing. Having no luck, tells us nothing. What format are the movies in that are located on your hard drive?
Originally Posted by drew23977
What type of files are on your hard drive ?
How are you trying to burn them in Nero ?
What is happening in Nero (error messages) that results in you "having no luck" ?
Do they not play properly ?
Are they choppy ?
You using a DVD writer ?
We can't see your screen from hereIf in doubt, Google it. -
Hey drew23977 Where are you????
Lots of people are trying to help but can't due to the lack of detail. It's almost like " I can't start my car, can you tell me why? "
If you have a VIDEO_TS folder in you HD, then it should be a piece of cake. However I suspect you have a bunch of Divx or Xvid and you want to convert to DVD but I could always be wrong. Please come back and correct me so I and the rest might suggest something that might help you out.No DVD can withstand the power of DVDShrink along with AnyDVD!
do you know a good freeware hard drive copying program?
By edong in forum ComputerReplies: 10Last Post: 25th Aug 2016, 20:50 -
copying a Windows XP hard drive
By joecass in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 10:00 -
Copying and converting files to external hard drive
By soxenme in forum Newbie / General discussionsReplies: 4Last Post: 25th Feb 2009, 17:16 -
Copying Your Hard Drive
By wulf109 in forum ComputerReplies: 6Last Post: 8th Feb 2008, 23:13 -
I want to reauthor DVDs without copying to the hard drive first.
By Big C in forum DVD RippingReplies: 2Last Post: 24th Jul 2007, 19:54
