I used the resize filter to create a frame around an AVI file (so it wouldn't cut off the subtitles when watched on a television). It worked, however, it resulted in a 24 GB file.
Anyone know what I did wrong?
If you save it in the default format of VD, it will be huge.
Use another codec to save. If you started with a Xvid or Divx, then use that codec to save it. There are also adjustments for the codecs, but that is more complex.
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Need to burn 24Gb video file to many DVD5's
By alegator in forum Newbie / General discussionsReplies: 11Last Post: 10th Aug 2010, 12:20 -
Error frame 0 in VirtualDubMod
By rocky12 in forum Newbie / General discussionsReplies: 9Last Post: 5th Aug 2009, 17:06 -
Uploading H264 in MKV container to Youtube results in frame rate problem
By tokintmash in forum EditingReplies: 10Last Post: 4th Apr 2009, 02:36 -
How do I edit the frame rate of a selection of frames in VirtualDubMod?
By manilow in forum RestorationReplies: 4Last Post: 21st Dec 2007, 22:12
