I am trying to back up my DVD which has lpcm audio. I can't compress the lpcm audio track (it is 1.5gb), which makes my DVD to big for a normal DVD-R. Even compressing all the video to maximum, it is still 2gb to big. I tried DVD shrink and Nero Recode but nothing lets me compress the audio. If I unselect the lpcm audio, then the main audio on the DVD disappears.
Try ffmpegGUI. It can encode your audio to AC3, which is a lot more compact than LPCM audio. There are other AC3 encoders also. AC3 from this type of encode is compatible with most all players.
LPCM is unusual for a manufactured DVD. Is it an mixed audio/video DVD?
Anyway, if you want to save space, LPCM takes up the most audio space, though may have the highest audio quality.
Just to add, DVDShrink and Nero Recode are not the tools you really need. You need to become familiar with stand-alone encoders and authoring programs. All-in-ones are not much help here.
https://www.videohelp.com/forum/viewtopic.php?t=234240 might assist.
If in doubt, Google it.
Help - LPCM 24 96 to DVD
By JorgeO in forum AudioReplies: 5Last Post: 10th Aug 2011, 07:47 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 09:15 -
LPCM 7.1 will not play in 5.1
By Modify_inc in forum Blu-ray RippingReplies: 2Last Post: 12th Jul 2009, 21:16 -
Best way to losslessly compress LPCM?
By dimtim in forum AudioReplies: 5Last Post: 13th Nov 2008, 11:56 -
Simplest and fastest way to compress LPCM audio to fit on DVD5
By kurbads in forum User guidesReplies: 5Last Post: 18th Sep 2008, 03:15
