After questioning rather to go with internal dl hp or benq, and thanks to your response I was all set to go with the benq 1625 lightscribe. My son, who has also been asking around, told me that he's heard good things about the internal dual layer LG 16x (I think there's only one DL - GSA-4163B). Okay has anyone had any experience with the the LG. I know it's not a lightscribe (but my son thinks that's just a gimmick anyways and that I should go with the best DL) What do you think Benq 1625 or internal LG? And with this info ..I'm buying one! Thanks for your suggestions/recommendations
If you want recommendations check out the LG & BENQ FORUM site at CDFREAKS.COM. If you don't want the lightscribe feature then I would suggest you get a BENQ 1640 drive which is the latest drive from BENQ.
BENQ DW1670 issues
By kyrcy in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jan 2010, 18:00 -
CL (in Ram) comparison
By Seeker47 in forum ComputerReplies: 3Last Post: 20th Jan 2009, 16:01 -
Which Benq DVD burner is the best
By Habby in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Oct 2008, 13:43 -
BenQ firmware can't handle 8X DL
By miamicanes in forum DVD & Blu-ray WritersReplies: 8Last Post: 5th Feb 2008, 14:27 -
BenQ DW1640
By jeet49 in forum DVD & Blu-ray WritersReplies: 2Last Post: 12th Nov 2007, 18:48
