Anybody has one of these puppies and used them with a mac?
GZ-MG40
http://www.jvc.com/product.jsp?modelId=MODL027545&pathId=119&page=1
It has usb 2.0 only but there is supposedly some software that comes with it that will allow you to transfer the movie to your cpu and edit it into imovie
Havn't used it with a Mac and don't have one, but have run into similar problems with set-top DVD recorders and editing MPEG2 from DVD-VR discs.
The software that comes with it is Pixela Capty MPEG Edit Ex (ver. 1.3). JVC says it is for data transfer and simple cuts-only editing on the Mac.
You have a few options...
-do simple cuts with the Pixela software and author a DVD w/ Toast or DVD Studio Pro, or
-convert the MPEG2 to DV with Cinematize or DVDxDV and then edit in iMovie and burn with iDVD.
Run-time hell - Longer on camera than on copied file on hard drive
By Qwerty69 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 2nd Jul 2011, 18:12 -
Need a hard drive? 2TB eSATA/USB2 for $99
By lordsmurf in forum ComputerReplies: 13Last Post: 12th Dec 2010, 12:08 -
How do I transfer shows recorded to hard drive to DVD?...
By Tigergreg in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2008, 20:35 -
Transfer miniDV to hard drive. Does it matter what software is used?
By vid83 in forum Newbie / General discussionsReplies: 9Last Post: 11th Dec 2007, 20:08 -
Everio GZ-HD7 60GB Hard Drive
By npdigital in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2007, 03:54
