Wonder if anyone around has used this software ???
If so, I wonder if someone can help as how exactly do we save the FINAL movie, so can use Nero to burn it on DVD ???
After finishing around 1 hours & 10 minutes of project, I tried converting the project into movie, by going through File > Export > Adobe Media Encoder & selected "PAL DV High quality 4Mb VBR 2 Pass" & after around 3.5 hours, I ended up getting the movie, but with video as different file & audio as different file. Wonder why is this the case, rather than having BOTH video & audio in a single file ???
Closed Thread
Nope, I'm NOT God, but I'm British (which is the next best thing ;) !!!
1000's and 1000's use this software ..
you have to author the streams..
maybe instead of buying the expensive pro software premiere - you should have started with a simpler program first ..
see guides and lots of info on these here and on the 100's of premiere sites .. as well as in the manual .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
you're doing fine..
Its just that your own workflow above is
missing a step
before you burn with nero, you must author a DVD!
a good companion to your Premiere Pro would be Adobe Encore
an authoring application makes -or- at least, arranges-the
menus and buttons to launch your clips (streams)
Hi thanks for your reply. You got the point there, since it was a very first time, I've had a chance using Adobe Premiere Pro. after using Microsoft Movie Maker, in the past, however, I haven't paid a penny towards this software, since I got it off my friend for freeOriginally Posted by BJ_M
You are in breach of the forum rules and are being issued with a formal warning. No warez. If you had actually bought the software, maybe then you'd not have these beginner questions. It comes with a nifty manual when you buy it.
/ Moderator lordsmurfNope, I'm NOT God, but I'm British (which is the next best thing ;) !!!
Questions about using Adobe Premier Pro
By Graemey in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 07:02 -
not enough disk space - Adobe premier Pro 2.0
By Reggie6966 in forum Newbie / General discussionsReplies: 11Last Post: 8th Nov 2009, 04:07 -
Adobe Premier Pro to dvd
By tat2loo in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2008, 13:57 -
5.1 AC3 and DTS in Adobe Premier Pro
By zerohash in forum Authoring (DVD)Replies: 6Last Post: 25th Sep 2007, 08:39 -
Duplicating people using adobe premier pro 2
By vipertongn in forum EditingReplies: 20Last Post: 12th Jul 2007, 02:07
