Last week i bought an lg rh7500 (dvd recorder+hd and divx player).
When you play a divx movie you can't use the forward and backward functions! if you miss a word of the movie you have to watch it from the beginning if you want to see again a sequence....
i didn't expect it from a manufacturer like lg.
Anyone of you know if there is any software upgrade or a way to solve this problem?
thanks a lot
Much of this is the way DIVX/MPEG-4 stuff works. There is no standard, so not all files will play. It is likely a safety precaution more than anything else. Meaning FF'ing a file may never come back, you'd have to start it over.
No problems with FF/RW on my player. The LG players that I have seen have been MTK based and also had no such issues.
MPEG2 as used in DVD also uses bframes, so I can't really see MPEG-4 being that big of a deal. -
Audio sync ... VBR audio... things like that screw with FF/REW and playing correctly again when normal speed is resumed.
I have a LG418, I have had no problem with FF /RW on dvix, xvid, or vcd formats.
Same here with my LG LDA-531, it works as good as FF/REV with standard DVD's.I have a LG418, I have had no problem with FF /RW on dvix, xvid, or vcd formats.
Don't go saying LG DIVX players are awful, based on one model! I challenge anyone to find a better Divx player than the 531.
Jeff
dvds don't play on all players
By sharrrri in forum Newbie / General discussionsReplies: 9Last Post: 22nd Feb 2012, 07:12 -
Where to buy in "used" condition SignVideo products?
By Writech in forum RestorationReplies: 1Last Post: 17th Aug 2010, 09:41 -
Don't buy...build your next computer!
By rcguy1 in forum Newbie / General discussionsReplies: 38Last Post: 17th Sep 2008, 12:12 -
Do you buy products off of infomercials?
By yoda313 in forum PollsReplies: 27Last Post: 11th Aug 2008, 16:36 -
don't buy Pinnacle Studio 11!
By rcguy1 in forum Newbie / General discussionsReplies: 21Last Post: 25th Jun 2008, 00:54
