Hi all,
I'm new enough to DVD authoring not to be too embarrassed by my first attempt at creating a multimedia DVD using Vegas and DVD Architect.
Considering I was limited to using 2nd generation VHS footage for the movie part of the DVD, imported to my PC via an ADVC-100, the result is not too bad and plays back flawlessly on the PC.
I then took the DVD to a friend's place, to check it out on their DVD player/TV system. Shock! Horror! It looks like sh*t.
Throughout the movie, when it showed people moving/walking on the set, the image of the person walking appeared to be broken into what I'd describe as a series of rapid still images, one after the other. When the subject was more or less stationary, this choppiness disappeared.
I haven't any idea what this might be, or what is causing it. I've been searching for info here and on the web and wonder if it's caused by interlacing/deinterlacing or something like that. I've since discovered it's probably best described as 'motion artifacts' (?).
The DVD is in PAL 25fps format. It was compressed for DVDA using 4 passes in CCE 2.67
Any pointers much appreciated. What should I be reading and where should I be looking?
Thanks ~ John
I am not expect by any means but to me it sounds like you have your field order mixed up. I had a similiar problem when I captured some VHS on my last project. Once I straighten that out, everythnig was fine. Good luck.
Mako -
Thanks m8
I have to be honest and say I haven't a clue what that means, nor how I got them mixed up, if I did.you have your field order mixed up
Perhaps someone would kindly interpret for me.
John -
The field order is determined largely by what type of device your using. In general DV devices like the Canopus or a DV cam are lower field or bottom field.
Whenever you have encoding options such as where you set the bitrate, audio type, etc you should find a option for top, bottom or frame based. Select bottom anytime you have this choice when using footage from the canopus.
There's more here:
https://www.videohelp.com/forum/viewtopic.php?t=257631&highlight= -
Thanks coalman.
I let my fingers do the walking, to your much appreciated links plus some other stuff at DigitalFAQ.com etc.
I also found the ReStream utility.
Some info says to select top field, others say bottom field. I'll do a bit of reading and see what makes sense.
John -
Top or bottom? Match your source, easy as that.
If it looks bad one way, it's obviously the other.Want my help? Ask here! (not via PM!)
De-interlacing problem?
By fredo2010 in forum Video ConversionReplies: 17Last Post: 27th Oct 2010, 16:48 -
Interlacing lines during .mts playback.......
By zacko in forum Newbie / General discussionsReplies: 10Last Post: 6th Jan 2010, 21:26 -
Good Video Explaining Interlacing and De-Interlacing
By Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 20:50 -
DVD --> x264 MKV - I think I'm having an interlacing problem? (Sample Vo
By mob in forum DVD RippingReplies: 13Last Post: 14th Apr 2008, 21:43 -
Interlacing problem with back-up of a dvd
By bgart13 in forum Newbie / General discussionsReplies: 16Last Post: 9th Apr 2008, 14:31
