I have a toshiba laptop....a dinklink wireless network card. and its says i got a strong signal and im connected but just cant get on the internet. linksys wireless router but when i try to repair the network connections it says it failed renew the ip address... im stumped
Have you tried ipconfig /release and ipconfig /renew from a command prompt?
If you have a Linksys WRT54G and you have a firmware older than version 3.03.9, the wireless link will stop working after transfering large files.
What kind of router and version you have? The version should be listed and the botton of your router.
Try unpluging and pluging back the power supply of your router and check if you can repair your wireless link.
wireless network connections in range report
By vhelp in forum ComputerReplies: 4Last Post: 17th Jan 2012, 01:04 -
Can't use one of my XP pc's on network (Network experts)
By neworldman in forum ComputerReplies: 5Last Post: 21st Jan 2011, 16:12 -
Network printer on separate network?
By Lucifers_Ghost in forum ComputerReplies: 7Last Post: 5th Dec 2008, 14:52 -
HDMI connections
By Prot in forum DVB / IPTVReplies: 2Last Post: 20th Feb 2008, 18:06 -
HD connections?
By James in HD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 13th Nov 2007, 18:02
