In FCP, when exporting a file using compressor, MPEG2, you can set the maximum bit rate and the target bitrate...ultimately for DVD Pro burning.
If I have plenty of room and want the best quality, I was told to NEVER exceed a target bit rate of 5.7 and a maximum of 6.5, much less than the maximum because it will not increase the final dvd's quality and will be unplayable in many dvd players that would otherwise have been able to play it.
If I have the room on the media, what is the highest i should/could go?
I'm not at my Mac now so please excuse any misnomers.
thanks
If you get a BitRate Calculator, which you WILL need if you are serious about DVD Creation,
you can calculate EXACTLY what you need
as far as your Target and Max bit rates.
I will only give you this: Their is rarely a need to exceed
6.0 MAX on the discs I have created, rarely even
still exceed 7.0 MAX.
The BitRate Calculator is an essential tool, go get it."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
http://dvd-hq.info/Calculator.html
here's another calc to check out. this is one i like a lot. but you only really need to use one if you're going to have more than 90 minutes, or a ton of ROM content. and i'd always ac3 the audio too. and most calc let you factor this in too.pants on, pants off, pants the floor. -
Custom Export Settings (Premiere Pro CS4) *Height
By BoLane in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 24th Jul 2013, 20:47 -
Need to export movie in Premiere Pro 1.5. What settings?
By vid83 in forum EditingReplies: 5Last Post: 23rd Mar 2013, 18:13 -
Best Export Method for FCP?
By Jeff_NJ in forum MacReplies: 1Last Post: 4th Nov 2011, 13:12 -
FinalCut Pro settings for YouTube work & export?
By MikeBell in forum Video Streaming DownloadingReplies: 1Last Post: 30th Nov 2008, 11:37 -
FCP Downconvert and Export 16:9 to Quicktime
By Jeff_NJ in forum MacReplies: 1Last Post: 24th Oct 2008, 12:45
