When I make a back up of a DVD I like to copy the actual disk with my scanner and then print that onto the DVD so it looks as much like the original disk as possible.
I use the software that came with my Epson Stylus Photo R300 and the color is washed out compared to the original. I try changing the settings to increase brightness and or contrast and or gamma but all I get are different looks not better.
Does any one have a rule of thumb for this? I fully realize that it depends on my scanner settings etc and that no answer will be perfect. I just want to know what works for you,
When you installed your R300, did you load the EPSON color management software. I have my r300 networked between two pc's. On the pc that I actually installed the software on, the colors are good and correct. If I network to the printer from my other pc, the colors are off.
Rob -
That's interesting. I have the exact same set up. I'll try printing from the computer that is connected to the printer and let you know if it helps.
Epson print CD/Mac - photo editing for DVD label question??
By dvdguy24 in forum MediaReplies: 16Last Post: 20th Aug 2010, 05:51 -
EPSON STYLUS PX710W all-in-one
By kyrcy in forum ComputerReplies: 2Last Post: 15th May 2010, 09:00 -
Epson R380 Print Settings
By festeris101 in forum MediaReplies: 5Last Post: 20th Jul 2009, 12:41 -
Adding BLUETOOTH to Epson R300 using Dongle ... Which one works?
By Toaster in forum MediaReplies: 4Last Post: 13th Sep 2008, 09:19 -
To print labels
By mis3 in forum MediaReplies: 9Last Post: 23rd Dec 2007, 10:27
