Hi guys,
I am trying to create a 3 hour dvd (to fit in 2 dvds, so at normal encoding...to fit 120 minutes in each disc). Anyhow, I just want to estimate how much hard drive space I would need to store a 3 hour MPEG-2 file. Can anyone help?
Thanks.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Hi rain88,
The size of an encoded file depends on only two things: it's running time and the bitrate used.
So, a file with three hours of video where the video is encoded at 4,000kbps will be half the size (nearly - there are other minor factors) than 3 hour footage encoded at 8,000kbps.
If you're putting it to 2 discs, it's probably fair to assume that you'll aim to have the highest quality possible, meaning higher bitrates - enough to fill both discs.
As 1 disc is approx. 4.35Gb, 2 x 4.35 = 8.7Gb. So, I'd say 10Gb to be safe.
Use the bitrate calculator given above.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
How do i get a 2 hour 43 min video file into 366mb PSP 480x272 mp4?
By DarkShadowRage in forum Video ConversionReplies: 24Last Post: 7th Jan 2012, 20:12 -
2 Hour Long File Conversion ffmpeg
By wsander9 in forum ffmpegX general discussionReplies: 3Last Post: 8th Oct 2011, 00:23 -
One hour, 37min AVI file that I want to turn into a VCD
By penang in forum Newbie / General discussionsReplies: 23Last Post: 17th Feb 2011, 10:11 -
Single 2+ hour DVD file ripping to individual XviD files
By perceptionist in forum DVD RippingReplies: 2Last Post: 16th Mar 2010, 03:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
